I'm a friggin idiot!!
My system won't boot.
What exactly happens when you try to boot with the CMOS jumper in the wrong position? The manual says not to have the power even plugged in when you do this, so trying to boot I assume is even worse. Is my board toast?
I've tried clearing the CMOS the correct way but the system still won't boot. I've tried everything i can think of/read about:
No PCI cards in, not even a graphics card;tried AGP and PCI graphics;
No IDE devices attached;
No fans plugged in;
Reseated RAM in every slot several times; only 1 RAM stick;
Reconnected mobo power several times;
Reseated CPU several times;
Reset power, switched power on/off several times;
Check to see that board is not shorting against case;
Abit KR7A-R
XP 1600+
Crucial 2100 256
Enermax 431W
Should i start the RMA process now?
No fans plugged in;
Abit KR7A-R
XP 1600+
Crucial 2100 256
Enermax 431W
