Ok.. I'm through making coasters. I've used 2 different programs to do this, and neither of the two are working right. All I'm wanting to do is make a bootable CD with a custom config that has some of our utilities on it - and as of this moment, I can make bootable CDs till the cows come home that *boot* - but don't show you any of the data outside of what was on the floppy that the programs used to retrieve the OS. I've been using Nero 5.5 and Easy CD Creator 5.0. In each program, I've made the file system ISO9660, Mode 1, and in Nero unchecked the Relaxed ISO Restrictions. Everything is said to be compatible. All of my files are in 8.3 format - I've triple checked.. even made a cd with just one directory and a small file thrown inside to see if that would work, but no go. I've even tried a different OS (which again works, but a directory listing after you boot with it just shows the contents of the floppy you grabbed the image of - none of my added files are there). Oh and also as a note, if you look at the cd in a 9x/2k machine, you see all the files I've added.. it looks exactly right. I've tried MS DOS 6.2, Caldera DR Dos, DOS 5.0 - don't think it's an OS issue.
Has anyone done this successfully, and if so, with what program?
