Boot up problems , please help !
nitro237
967
whenever it starts to boot up , right after the video card info shows , it says
"BIOS ROM checksum error"
and under that
"Detecting floppy drive A media ...
INSERT SYSTEM DISK AND PRESS ENTER"
and makes a buzzing sound and stops bootup .
What could be causing this ?
It's a Soyo VIA motherboard ( about 2 weeks old)
PIII 667
128 meg PC 133
TNT 2U
Thanks .
BFG10K
22,709
3,008
Do you accidently have a non-boot floppy in the drive? Take it out if you do.
Also try to boot up off a rescue disk.
Danlz
550
After you follow BFG10K's recommendation and still no joy: go in the bios and either turn off floppy seek, or change boot sequence to C drive in front of the string. Kinda shoot'n blind here, but did it ever boot for you?
Danlz
550
progress...and BFG10K jump in here too...the last time I got a CHK SUM ERROR was from some bad (generic) ram. If you have any ram laying around it would be good idea to change it. Smells like you're not even getting a post of your drives, right?
RM1
Try this:
I think it is a "ACTIVE" state problem. Currently the error message indicates that your primary partition is "INACTIVE".
Here's what to do:
Use a boot disk, and have FDISK.EXE in it. Run Fdisk and view (Option 4, I think) the partitions. The primary partition must have a "A" or "ACTIVE". If not, it won't boot. Set it to active.
