- Jun 2, 2002
- 46
- 0
- 0
Everytime i start my computer now, a second after the XP logo comes up with the progress bar, i get a blue screen that says unknown hard error with ntdll.dll. It takes me about 15 tries to actually get the comp running because that keeps happening, i scanned ntdll.dll with a AV and it was clean, i also replaced it with one off the XP cd AND from the dll cache folder...nothing. This used to be a twice a week thing, now its every time i start my computer. Also, i get lock-ups which i posted about a while ago during games or while reading. Is it possible that a faulty power supply could cause these problems? Or maybe not enough power or a power drain from stuff running? I dled the diag tool from western digital and did the extended test and it said everything was fine. So, im really confused and desperate to get everything to work properly. Any info/comments will be appreciated greatly. OH, BTW i can boot into safe mode everytime i try with no errors but my actions are limited because of cut down drivers :/ i can get the specific code but it is Unknown Hard Error with ntdll.dll and the error code is i think C0000021. when i reboot i'll check and post.
A7V266-E MB
Xp1800+ CPU
512MB Mushkin DDR RAM
Internal CR-ROM & floppy drive
External CD-RW
80 GIG WD HD & 2.5 GIG maxtor HD
SB Live! value
Evga Ti4400 128MB Video Card
1 PCI slot Fan & 1 case fan
CodeGen 350W PS
A7V266-E MB
Xp1800+ CPU
External CD-RW
SB Live! value
CodeGen 350W PS
