lavagirl669
Just installed Antec True Power 510W PSU. Previous troubleshooting led me to failed PSU.
Hooked everything back up double checking all connections.
CPU, Vid Card, everything working.
Recently changed CMOS battery.
Hit Power and I get one of 2 things:
No beep and no Video (yes card is running and fan is spinning) just fans going
along with everything else.
When I reset my CMOS jumper (power unplugged) I get the normal 1 Beep
But then I get - 2 and then 1 beep (2-1) (Can't find this beep code anywhere so don't know what it is)
and then the Post Screen - ***Tried to hit delete to get into BIOS at this point and it would not
go***
Instead I get an Ameritrends black screen with System info
and one of 2 error messages:
CMOS settings wrong
OR
CMOS battery low
I try hitting F11 for Setup as it says to
then F1 ***Nothing happens*** BLACK Screen and System is running but nothing happens
Shutoff power and tried again
Get same Post and then Ameritrends Black screen with system info
Hit F11 for Setup
then
F2 for default settings
It goes to a "Select First Boot Device" screen
with Floppy, IDE 0 (HDD), or CDROM as my options.
I hit IDE 0 and next get a black screen and NOTHING
Tried switching off power and trying again and same thing.
Next time I try I get NOTHING again NO Beep, nothing until I power off and reset CMOS again
and then same as above
Help! Someone suggested I needed to reset CMOS settings, but I can't even get into it.
Could this be a MOBO problem?
Thanks in advance!
Lavagirl
go***
CMOS settings wrong
OR
CMOS battery low
Hit F11 for Setup
then
Thanks in advance!
Lavagirl
