boot problem 3570k i5 4.4ghz
MasterJakobo
Hi, i built my pc 2 weeks ago and i started overclocking it and got something stable at 4,4 ghz offset -0.035 with llc set at ultra high and 1,7 pll voltage. I ran ibt at maximum for 12 hour with no error i also ran prime95 for 2 hours no problem. I played hours of dirt showdown and diablo III. My temps are excellent idle at 25-28 ish and 0,888 vcore Load temps are 65-78 at 1,232vcore
Ok heres the problem, sometimes when i cold boot my pc it beep 5 times in loop and i have to jardin reboot it then i get overclocking failed please enter setup message. It never happen when rebooting. Everything else work fine. I also had a bad CPU error code(5 beeps) when i first built my rig but it was a bad CPU so i did rma it and this is the new one. My motherboard had a bent pin on CPU socket but not so bad like i said everything work perfectly.
I did alot of search on google i even reseted my bios and i updated it Please help me guys.
My build is
I5 3570k Asus p8z77-v pro Corsair a70 CPU cooling Corsair carbide 500r Antec truepower 750w su 4x4gb low profile corsair 1600 mhz vengeance gigabyte gtx 670 oc
Welcome to the forums MasterJakobo! :thumbsup:
Does your system have the same cold-boot issue if you decrease the amount of overclocking you are doing? Does it do it when the CPU is at stock?
My build is
Post bios screen shots of Everything you have relative to overclocking
Including the first page of memory timings.
Hit f12 to screenshot onto a USB device.:biggrin:
