- Sep 25, 2006
- 348
- 0
- 0
occasionally when booting up my htpc i get a message during boot, instead of "verifying dmi pool" i get "building dmi pool" followed by "flash rom protected", which consequently leads into a no system disk detected.
power off, power on will reboot fine. happens perhaps 1/3 boots. does not matter hot/cold boot.
system specs:
amd athlon64 x2 4200 windsor am2
patriot 2gb (2x1gb) pc6400
wd 72gb (2x36gb) raptors in raid 0 boot drive
gigabyte m57sli mainboard
evga 7900gtx gpu
550w psu
windows xp sp2
some research has suggested a possible weak board battery, but the board is less than a year old. i'll probably pick up a battery and try it anyway.
is there some item in the bios config that could cause this? i seem to remember having a similiar problem on another rig that was related to usb devices being plugged in during boot. this system does have quite a few usb devices, including wireless logitech keyboard, wireless gyration mouse, wireless linksys card, storage drives (off during boot), wireless logitech gamepad and an apc ups.
have not tried updating or clearing the bios yet, thought i'd get some feedback first, any help appreciated.
some other info from a post i found yesterday with other folks having this problem, however with my board not being the same that the thread was about i figured it needed it's own thread.
system specs:
evga 7900gtx gpu
550w psu
windows xp sp2
originally posted by: chansigril
Originally posted by: cdfire
Originally posted by: TheBeagle
Good Evening Everyone.
The F4f BIOS seems to work pretty much the same as the F4e one for me. However, I'm still getting an intermittent condition on boot up (using Vista Ultimate), where at the end of the POST, the last screen line says:
"Building DMI Pool.................................Flash ROM Protected"
Then the whole thing reboots and goes through the POST process again. However, after a number of reboots, when it finally decides to go into Vista, the last line on the POST display reads as follows:
"Verifying DMI Pool Data......................."
Once in Vista the whole rig is rock solid and functions perfectly.
I'm using these settings:
FSB = 378
Multiplier = 9
Vcore = 1.450
DRAM = 2.25V
Speed = 3.4 GHz
For the life of me, I can't seem to figure out why it takes several boot cycles in order for Vista to make the jump into Windows. If anyone has a REAL solution for this situation, I'd like to hear about it. Thanks. TheBeagle
This is exactly what I get every once in a while in Windows XP Pro 32. Pc runs great, but every once in a while upon reboot or system startup, I get this same thing. "Verifying DMI Pool Data......................." and then I have to reboot to get into windows.
As stated before I also get F2 showing in any windows program which shows the BIOS only it will be followed by the new BIOS File date, so say I use F4f, it will show F2 with the F4f BIOS file date.
I guess with this board we skipped a lot of the issues the other 680I boards have, but have a couple new bugs to work out.
i came across this thread while googling an identical problem. however...
i am using a ga-m57sli-s4 with an athlon64 x2 4400+ cpu. i do have raided 36gb raptors on this system along with a number of wd storage drives. i did not have this problem when this was my gaming rig in another case, but the issue reared it's ugly head when i switched cases and began using it as a htpc, along with many usb peripherals.
my problem is identical.
i am confounded by this problem quite frankly, i have done quite a bit of research and have found no solutions. i have not flashed the bios on this board yet since the problem was not existant prior to the case swap.
just my 2c, any ideas are appreciated
