As I mention in another thread, I'm a PC user who got a Mac Pro and MacBook Pro for work but have to use Windows (lack of software support for Mac). While I can navigate in XP fine, as well as work with simple stuff on Mac fine, I have some IT related issues that I am not able to answer myself (sad, because I used to do tech support for university 12 years ago).
1) I'm trying to use Acronis True Image for WD hard drive to clone or backup my XP/BootCamp image, but it said my drive is not recognized. Are there any ways around it? My goal is to move this partition to another hard drive I bought, BootCamp is way too slow for me, as well as the hard drive that comes with the Mac Pro is not fast enough (building code that has a size of 8GB and takes 3 hours, and spend most of its time navigating source code).
2) I want to know if there is a better way of finding which printer is which IP address if I install these printer from Bonjour. This got to be the worst kind of printer setup software for a work place (although it is excellent for home).
3) What is the best way to clone the entire Disk (both the Mac and BootCamp partition) and resize these partitions? Free apps please if possible.
4) I heard about key remapping software for boot camp that you can remap alt/windows, function keys, clear, fn, etc. Where is this software (or where is the configuration? I couldn't find it in boot camp).
Thanks in advance.
Thanks in advance.
