Originally posted by: Zim Hosein
but i know ppl that burn at 30 seconds....
Those people are
lying to you IMO willboxer.
I've used both Optimum, TDK & Fuji and I've been happy w/ the results, Fuji blanks are nicel, but a little too rich for me at my local stores.
yeah fuji's are expensive but i always look for deals
price range is basically 10 cent per CD for me...give or take a bit. and with the deals going around at anandtech there's always deals out there before i use them all up.
but anyways, so you're sure they're exaggerating when they say they burn within 30 seconds?
see my brother's CD burner which is a 24x burns at the same speed as i, and mine is a 52 (of course he might've upgraded it, since 24x lite ons are upgradable)
but by doing the math, it looks like i'm only burning at 24.xx speed, which is not anywhere close to what this burner claims to be capable of (i did a speed test on nero, but funnily enough when it finished testing the speed and ran at 24.xx it burned in 3-4 min and not 2:30min which it would do if i didnt run the test speed thingy)
EDIT:
Those people are
Uh, 30 seconds?
I suck at math, and I can tell you that is not possible.
1X = 150kb/sec
52X = 7800kb/sec(7.8mb/sec)
700mb / 7.8mb = 90 seconds, or around 1.5 mintues.. However, you cannot burn at the full 52x for the entire length of the disk.
2.5 minutes is completely normal.
ah ok, well if it's normal then i'll just leave it as that, i got mine for pretty cheap, like 25 bucks so i shouldnt complain
