Hey all,
I'm trying to tweak my home network to go all wireless. Our current setup involves the cable modem sitting in the family room, with a cable running to our Linksys WRT54GS wireless router in our living room.
We're renting my friend's house and he won't let us just put a cable drop in the living room. Probably about a 30 ft run down the hall.
Now we have a little run running around the house and we'd like to get rid of that cable run.
I'd like to go wireless ... I'm already wireless on my wife's computer. However, I'm having some signal strength issues.
If I have the router/AP in our living room, the signal strength is just fine ... but then I have to run a cable. However, when I have it in the family room next to the cable modem, I get a significant drop. 36Mb is the best connection I get, and the signal strength is reported as low.
I downloaded Sveasoft's Alchemy firmware to boost the output to 251mW, but that hasn't helped much.
I'm probably going to buy a Linksys wireless PCI card with Speedbooster for the network. However, my question is, what is the best way to boost the signal so I can get full throughput? I've looked at getting an access point for the living room to work as a repeater, and also Linksys's "plug and go" access point along with some higher gain antennae.
All network cards I have at home use the Speedbooster technology, so I'd like something that would work with that.
Any ideas that could help?
Thanks,
Super
Thanks,
Super
