Boost wireless router range
Platyply
105
I have a Belkin N1 Wireless Router and there is no signal on the other end of the house, what can I buy to extend the signal to the other end of the house?
Thanks!
JackMDS
29,563
432
Option 1. Daisy chain with one CAT5e wire.
Can be done with any Wireless Router like this, http://www.ezlan.net/router_AP.html
Option 2. Wirelessly (Without a wire), Repeater/WDS solution.
Wireless Modes - http://www.ezlan.net/Wireless_Modes.html
Can be done with Routers that support WDS or can be made into supporting WDS with 3rd party firmware.
Set WDS
Reasonably priced solution is to buy few Wireless Routers and set them as WDS system
You start with two units, and continue until everything is covered.
Please Note that most Routers do not do WDS as is.
Example for one that does, http://www.newegg.com/Product/...181218&Tpk=zxell%2b550
Some Routers do WDS after Flashing a 3rd party firmware (Linksys WRT54GL).
http://www.dd-wrt.com/wiki/index.php/Installation
http://www.dd-wrt.com/wiki/ind..._Linked_router_network
The base unit that is attached to the Modem should be configured, as a regular Wireless Routers.
WDS units configured like this, http://www.wi-fiplanet.com/tut...ls/article.php/3628576
P.S. D-Link and Netgear 802.11g Routers do not support WDS and cannot be Flashed with 3rd party firmware.
