I'll get right to it
New 2.4c, Abit IC7 with passive heatsink (lapped Tiger1), 2x512mb Crosair XMS3500 sticks.
I got this, popped it in, and jumped to 3.4ghz. I Prime95'd it for 12 hours at a time and never had it crash. Load temp was 52c (Which, if I have read correctly, is 10c~ higher than other brand boards) and the case temp was 25-27c. Now, this was with the side panel OFF. After constant days of use, and at night running dual Prime95's, I figured it was stable, so I popped the side back on this morning.
Decided to run dualie Prime95s again , and 1 failed after 4 hours. The load temp during that time was 56c max, case temp reaching 32c.
It wasn't a rounding error, which I usually get when it's not stable, instead it said: FATAL ERROR: Final result was 4ED9A32A, expected: 025B1320.
So, what do you guys think it is? I am pointing towards the passive northbridge heatsink, but I'm not sure. I think I have the case pretty well cooled, so replacing fans probably won't do anything. It also could be the memory getting hot. I really don't know what I should try, but for now I bumped the voltage up by .25 and I lowered the ram timings slightly and trying again.
I don't think that will do anything though, since it was stable with the side panel off, but it's something to try in the meantime
