BOINC installation issues...
BobTheWizard
545
Since SETI Classic is for the most part come to an end, I decided to switch back to BOINC and for some reason it wasn't working, so I reinstalled it. After reinstallation, I can't seem to get past the "Select Computer" option, with it telling me that "BOINC Manager is not able to connect to a BOINC client."
I select "local host" for the computer. That's what I find in other instructions as the correct setting.... I also allow BOINC Manager and boinccmd through the Firewall.
I'm using the latest version of the program, 5.2.12. What am I missing here?
I know someone here has an answer for me.
networkman
10,436
I got that same thing, "BOINC Manager is not able to connect to a BOINC client." recently too.
In my case, it was in upgrading the E@H client from 4.19 to 5.2.8; with an upgrade, you have to uninstall the old Boinc client, then install the new version, but when I tried that, I got the same message that you're getting.
After doing some reading and not finding anything, I found that I was able to upgrade to 5.2.2 as an intermediary step, and then upgrade to 5.2.8. Not sure of the reason, although I suspect it has something to do with the login process. Sometime after 5.2.2 the process got changed to a login with email and a password, rather than putting in a website and that long string of numbers/letters for the project.
So my suggestion is to try an older version like 5.2.2 first -- I know for a fact that it works. :)
Rattledagger
2,994
19
Well, haven't had any problems when installed BOINC as service, so not sure what it is...
But anyway, v5.2.13 is released, with 3 changes:
Localization updates.
Network communication failure page added which describes basic ways to resolve common networking issues.
Fixed a timing issue where the manager would look for the password file before the client actually created one.
Smoke
Distributed Computing Elite Member
Jan 3, 2001
12,650
207
Bob, I ran into a similar problem yesterday and also was puzzled.
I ended up un-installing BOINC, re-booting, and then doing a fresh install that seemed to fix whatever the problem was. Give that a shot. :)
networkman
10,436
Yes, that would definitely be a problem! :p
IGBT
17,976
141
..what are the best settings for BOINC/seti for dial up service? And any way to get the classic screen saver instead of the new 3d thingy??
Rattledagger
2,994
19
The screensaver will not look exactly like the "classic" did, but you can change some preferences and get more close look-alike, see here
As for dialup-settings, this depends if you wants it to auto-dial at will or manually connect...
Anyway, atleast around here dialup is paid by the second, so if I've been forced to use dialup would never let anything auto-dial.
This would mean:
Connect to network about every
(determines size of work cache; maximum 10 days) atleast 2 days, would not recommend higher than 7 if you're not routinely offline for a week...
Confirm before connecting to Internet?
(matters only if you use a modem) no
Disconnect when done?
Maximum download rate: no limit
Maximum upload rate: no limit
Use network only between the hours of
Enforced by versions 4.46 and greater (no restriction)
In BOINC Manager, would when dialed-in choose "Commands - Network activities based on preferences", wait for all uploads-downloads to finish, possibly report one more time, and afterwards "Commands - Network activity suspended" till next time connects...
So, depending on if you wants to let it auto-dial or something, you can change the preferences. To not let the client dial-up for each wu, you can limit with "Use network only between the hours of ...". The choise is really up to you...
IGBT
17,976
141
This would mean:
..thanks very much for the help. I'am going to set it up so it advises me that it needs attention when it finishes a data unit..then I can dial out as necessary to return the data and get another unit. That's how I had it set up with seti classic.
BobTheWizard
545
Still doesn't work.
Makes me feel pretty stupid too...
I'm leaving it off for now, too anoyed to work with it any more. I've tried for 3 days.
Ignore the sig below.....
IGBT
17,976
141
..ok. I've completed my first seti/boinc work unit. How do I manually upload the results and get another work unit?? I'am using dialup.
BobTheWizard
545
I finally got the program to work by installing it as a service. I tried that originally but couldn't remembe the password for my log in so I was not able to complete the installation. I never got it installed as single user" or "shared user" for some reason, but whatever... heheh...
Now, I am trying to attach to the Seti@home project .... It won't attach. Any clues as to why? Anyone else having trouble getting work to work on?
Smoke
Jan 3, 2001
12,650
207
I've been working on my grandson's computer and just tried to download BOINC without success. I am guessing that they are probably having server problems at the moment and that might explain why you are having troubles "attaching" a project.
And good morning TeAm. :)
Rattledagger
2,994
19
Yes, the SETI@home/BOINC data-server seems to currently be swamped...
Hmm, according to the status-page the upload/download-server was disabled for a short time, so maybe a quick re-start of Apache or something has hopefully fixed the problems...
Anyway, on Wednesday they moved downloads of the BOINC-client from the BOINC-server to the SETI@Home/BOINC-ul/dl-server, since all the client-downloads was interfering with the rest of Berkeley campus-traffic. This of course increased the load on the SETI@Home/BOINC-server even more.
Maybe moving client-downloads to the "classic"-data-server would have been a better idea... :evil:
BobTheWizard
545
The latest version is 5.2.14, just released this morning to try to address this issue I am having. It should be available....
But I still can't attach to a project.
This is what I get for messages....
12/4/2005 7:37:44 AM|http://setiathome.berkeley.edu/|Requesting 8640 seconds of new work
12/4/2005 7:42:48 AM|http://setiathome.berkeley.edu/|Scheduler request to http://setiboinc.ssl.berkeley.edu/sah_cgi/cgi failed with a return value of 500
12/4/2005 7:42:48 AM|http://setiathome.berkeley.edu/|No schedulers responded
12/4/2005 7:42:48 AM|http://setiathome.berkeley.edu/|Couldn't connect to URL http://setiathome.berkeley.edu/.Please check URL.
12/4/2005 7:42:48 AM|http://setiathome.berkeley.edu/|Resetting project
12/4/2005 7:42:48 AM||request_reschedule_cpus: exit_tasks
12/4/2005 7:42:48 AM|http://setiathome.berkeley.edu/|Detaching from project
Freewolf
9,673
I don't do boinc seti but you can alway try to attach to another project like Rosetta and if that works then you know the problem is most likely with the seti servers.
Rattledagger
2,994
19
We are experiencing heavy traffic on our data server. This is preventing some workunit/core client downloads. We are working on the problem.
So, one possibility is they've swamped with requests.
Another is you've got a connection-problem, firewall or anything that screws-up.
Can you do a tracert to setiboinc.ssl.berkeley.edu
If you tries to open http://setiboinc.ssl.berkeley.edu/sah_cgi/cgi in a web-browser, does you get a "403 Forbidden"? If not, it's no wonder the BOINC client can't access the server...
Does "attaching" to another BOINC-project work?
BobTheWizard
545
I've been looking into this and it seems like a problem with packet size or something like that. Not sure what the solution will be but I'll gonna wait a bit before doing anything else.
I did a tracert to setiboinc.ssl.berkeley.edu and it works fine, and the firewall is open to boinc.exe and boincgui and boinccmd.
When I try to open http://setiboinc.ssl.berkeley.edu/sah_cgi/cgi in a web-browser, it does give me a "403 Forbidden"? That's not the problem.
I'm gonna try Rosetta for awhile and see if that works. I'l just wait a bit and see if they come up with a solution.
It's weird though.. I did have BOINC working for SETI for awhile months ago. I don't know what changed between then and now, but it doesn't work. But oh well...
Freewolf
9,673
Rosetta's a great project. You will see a lot of familar names there.
IGBT
17,976
141
..decided to let boinc/seti go. Numerous screen lock up's..crashes and failure to respond is too much to tollerate. Never had a prob.w/seti classic.
Wolfsraider
8,305
F@H - Protien research -- Aids, Cancer etc...
DPAD - particle beam
Community TSC - Childhood diseases
Dimes - Internet mapping
Seventeen or bust - math, prime number search
United Devices - grid research
There might be more depends on your intrests
Read about them here or here
(click on one of the links under the header - Science | Life Science | Cryptography | Mathematics | Miscellaneous |)
Hope this helps :)
Mike
