- Nov 22, 2000
- 55
- 9
- 71
https://www.officedepot.com/a/products/909597/TP-Link-60W-Smart-Wireless-LED/?cm_cat=1001215484
Put 2 in the cart and use Code 48908738 to apply the BOGO offer.
Description
TP-Link Smart Wi-Fi LED Light Bulbs have wireless connectivity, which allow you to control them remotely through the free Kasa™ mobile app. These bulbs also monitor energy usage for energy efficiency.
Light output: 800 lumens.
Energy used: 60 watts.
Built-in wireless connectivity. Turn the light off and on, and set scenes, schedules, timers and brightness with your mobile device.
Backed by the manufacturer's 2-year limited warranty.
Compatible with most Android and iOS mobile devices.
15,000 hour lifespan for extended use.
Dimmable design allows you to adjust the light to suit your liking from warm to natural. Frosted surface on the inside creates a soft glow.
Intelligent Assistant Compatible: Google Assistant, Alexa
Description
