Bnc cctv cable
jamesxy1
4
hello if anyone knows about bnc cctv cables i bought 1 of ebay got it 2 days later plugged it in and it worked for about 11 hrs same day then next thing the picture is lost says no signal so i unpluged it plug it back in says the same.. so i re-pluged my old 1 back in and tht still works anyone cud help cheers.
corkyg
Elite Member | Peripherals
27,370
240
Just curious - was the BNC connector push-on or screw-on?
jamesxy1
4
u push the other bnc connecter in the bnc cable then u turn it .
corkyg
27,370
240
Got it. There are a lot of connect layers in that chain. Any way to simplify it?
jamesxy1
4
ok strange i found another power plug a 12v dc i tryed tht on my new cable and now i get a picture so now i have both cables pluged in on my 2 cctv cams lets see how long tht lasts...
