BNC cables for monitor??? how?
luv2liv
3,500
94
i have this 21inch monitor a friend dropped by.
but this looks really weird....
in the back, looks like 5 cylinders where BNC cables would normally be plugged in?
the first three is Video In with (R G B)
the last two is Sync In with (HD VD)
how do i work this thing? it looks like a really sweet monitor too! i only have a regular video card, the Creative Ultra geforce, is there an adaptor? or is this only for other machines like MAC, SGI, Unix?
sohcrates
7,949
well, if they really are bnc connectors, then you will need a vga to bnc adapter (available cheap on the internet, do a search)
of course, *some* 21 inch monitors that are older are so-called "fixed frequency" monitors and will only work with specific video cards...though i don't know of a way to verify that this one might be that way w/out actually getting an adapter cable.
luv2liv
3,500
94
wow, thanx!!!!!
i've checked it out, the cables are pretty cheap, thought it would cost me an arm or kidney
btw, is bnc cables produce better image quality? or was this old technology?
Leokor
214
<< i've checked it out, the cables are pretty cheap, thought it would cost me an arm or kidney
Both. BNC is an older technology, but it produces better image quality. :) The chief reason behind the D-Sub standard was not so much the quality as the combination of price and ease of use. Admittedly, though, the difference in quality is not that significant.
Leo
sohcrates
7,949
I just responed to your PM.
The monitor you linked to appears to be a fixed frequency model.
But the site looks like they might sell fixed frequency video cards, though you're not exactly gonna get any 3d support out of them!
