Bluetooth Question
jdogg707
I was wondering whether I could use a USB Bluetooth Adapter in my PC which is connected to the internet, and hook up my Palm Tungsten T2 Bluetooth enabled PDA and surf the internet on the Bluetooth connection. Is this possible and if so how did you do it?
Yep, its possible. Most likely solution is to (assuming XP on your desktop) bridge the two adapters (NIC and Bluetooth adapter), and set your PC to be your gateway on your PDA.
