morpheus305
I got this bluetooth keyboard http://www.newegg.com/Product/Product.aspx?Item=N82E16823701033 and the problem I am having is by default it's using the fn keys instead of the white text keys. So when i hit the letter "K" it types out number "2" which im guessing is numpad 2 since the keyboard isn't big enough for a numpad. I figured it was just some combination of Fn key plus some other key but i have tried everything and nothing seems to work. On windows xp I could hit fn+shift to switch between them but on windows 7 that key combination does what the instruction manual saids, it switches back to the other paired device(even though it's only setup for one device).
I am frustrated and spent hours on this. I googled every thing I could and still couldn't find out the key combo or any way to to switch the setting.
Edit: problem solved, can a mod plz delete this
