Bluetooth audio in car
Syringer
19,333
So my 07 3-series only has bluetooth capabilities for the phone, and not for audio/Spotify.
I'm looking for a solution that will allow me to play audio through bluetooth, the one caveat is that I want my phone to autopair to the device whenever I'm near, i.e. I don't want to have to go into my phone settings to connect it to the bluetooth every time.
I have something similar for my home theater but I do have to manually pair it when I want to connect to it. Any suggestions?
rbk123
748
351
New head unit (I'm guessing you knew that and have ruled it out, but just in case).
bigboxes
41,886
12,341
Yup. My 09 Camry-series had bluetooth, but was limited it what it could do. Got new Alpine single DIN with bluetooth, HD radio and Pandora controls under $200. Blows the old stereo away. Sound is fantastic and bluetooth usually connects automatically (after initial setup). Occasionally, I have to turn off bluetooth (on the phone) and then turn it back on. Get yourself a car dock and you are golden.
gorcorps
aka Brandon
Jul 18, 2004
30,739
454
That's weird you have to manually pair your phone to your HT every time. I have a Jeep GC and if my Bluetooth is enabled on the phone, it'll connect when the car turns on. I don't think the Jeep is special in that either, so I imagine modern head units would act the same way.
What s44 posted is probably your best bet though. You won't get to see what's playing like you would with a modern stereo, but it's a cheap solution if you have an aux port.
Zaap
7,162
424
I get in my car, not only does BT reconnect, PowerAmp auto-resumes playing the last track.
I'm guessing its all what version of BT? (4.0?)
vshah
19,003
24
look into grom or usa-spec adapters. They spoof an xm radio connection or a cd changer connection, and work with your car's steering wheel and radio controls.
not nearly as easy to set up as plugging in a BT aux adapter though. they need to be wired to the back of your radio. (although in some cars the xm/cd changer connection is in the trunk, in which case its super easy)
