what then? everything works fine if only one is connected. It specially seems to freeze if I either try to use my Bluetooth headset or using my network.
Could be a driver problem. I tried to disable the wireless device but still it still froze when testing my headset in sound settings. But when I unplugged the wireless device it runs fine, so for some reason these do not like eachother.
