<< The easiest way to do it would be to mod that 3-pin to 4-pin adapter. Looking at mine, I'll try to list the steps:
Find the Female 4-pin connector, it's the one that you would hook to the power supply line
you'll notice the red & black wires from the BLORB running to the yellow & black wires of the PSU.
If you pinch on the contact side of the pins, you should be able to back them out of the plastic casing.
You'll want to back out the pins for the RED wire (Red wire of the adaptor) and the BLACK wire (the one with the lead going to the BLORB, closest to the YELLOW wire), and switch them.
You should now have your wires going BBRY versus the RBBY that they were before.
This will cause the fan to cross the +12 & +5 volt lines, making +7 volts. That should be more than enough voltage to keep the GPU cool & be quieter. >>
hey scootin159
thanks for the reply! yeah i was wondering am i just making the switch on the female side of this 4pin adapter ? just wanna make sure
thanks! >>
Yes, the main idea is to connect the red wire from the BLORB to the Yellow wire from the PSU & the black wire from the BLORB to the Red wire from the PSU. >>
scootin159
u got me confused agian
so right now i have the 3 to 4 pin adapter.. the 3 pins ((yellow and black go into the male side of the 4 pin adapter.. yellow 3 pin going to yellow 4 pin and black 3 pin going to black 4 pin, both on the male side.. however the connection to my psu is female.. so im wondering which one do i pinch? the psu female or this male adapter
im confused d=(
