Would I be better off using a blue orb or a fan on the stock heatsink on the Northbridge of an Iwill KK266?
If the blorb, what would you use to attach it - the supplied tape? Since the mounting holes are 60mm apart, it wouldn't seem like the approach in link would work. (AS epoxy might be better, but I don't have any - and it seems like overkill for a chipset cooler...)
If you'd just attach a fan to the stock heatsink - what sort of fan, and how would you attach it? The heatsink appears too shallow (and small) to use a normal clip or screws.
ted
ted
