Blu-ray player and WIFI?
My new Blu-ray player has WIFI and the player sports a USB connection.
Question: Can I copy my WIFI password to the Blu-Ray player from the USB connector with a USB stick? I have a massive 64 digit key and I'm not lowering the key strength on account of a damn player.
unlikely it has that feature. Is there something wrong with using pen and paper to write it down, bring it over to the blu-ray player, and punching it in?
It would have taken you less time to just do it manually than asking how not to have to do it manually.
Edit:clarified
64....yup that is a pain. Only need to do it once though.
May want to run a wire to it, streaming video through WiFi can be sub-par.
I used to have a 64digit password, but it was such a PITA. Now I just use 15 digit passwords and change them out every now and again. Easy enough.
Also, I find that streaming Blu-Ray is ok over wifi. All my rips are around 6GB and they work really well. Image and sound quality is HD and good enough. If i want max quality video and sound then I just use the disc.
