Blu Ray playback problem
roguerower
4,563
The LG Blu-Ray drive that i recently bought has been working great, but with the two BD discs listed above, whenever I try and play them using PowerDVD 7.03, I get a black screen and then nothing. I've left it for 2 hours, come back and nothing has changed. I looked in task manager and the program was using 50% of my CPU (E8400 @ 3.0). Is it a problem with the software or drive? I've played at least a half dozen other BD discs w/o a problem and the discs in question work on a PS3.
SKORPI0
18,471
2,411
I would try to load it as a file. Using PowerDVD 7.3 built 3304
With Dark Knight BD try this, works for me.
1. Open media file.
2. Choose the blu-ray drive, should show as bd-the dark knight
3. go to BDMV, then STREAM.
4. choose 0007.m2ts (32.6 GB file) then click to ad.
5. click OK
6. Play the file.
BornStar
4,052
I have a Sony drive and PowerDVD 7.3 and I didn't have any problems playing The Dark Knight on my E6750. I have no other useful information for you, just that it worked without any problems with the same software.
