Blown capacitors on 8600GT
Zap
22,377
7
The first pic shows that the fansink was kind of dirty. It could be excess temperatures that caused the failure. Capacitors have a temperature rating.
Modular
5,027
67
While they do have a temp rating, that fansink isn't that dirty...
Elixer
10,371
762
Could be a bad batch of CAPS. We just can't tell just from looking at the pics, the card would have to be seen by someone who can diagnose the issue, aka XFX, or a good tech.
On the bright side, XFX has a 'Double Lifetime Warranty', so send it back to them, and let them worry about the cause.
Denithor
6,298
23
It's an 8600GT, is it even worth sending back for refurb? Just grab an 8800GS for $35AR and be much happier.
ScorcherDarkly
450
I had an XFX 8600GT blow 5 caps just a couple months ago. Unfortunately, when I bought it at the very end of 2007 I was unaware of the lifetime warranty and didn't register the hardware =(. Won't be doing that again. Mine also had never been overclocked, and while the sink was dusty, it wasn't overly so. PSU was a Thermaltake 430W purchased the same time as the card.
I thought about buying a new one, but decided to wait for ATI's launch to replace it and am getting by on an old 6800 until then. It does surprisingly well on newer games. Nothing to brag about, certainly, but playable frame rates on TF2, L4D and WoW, all at medium settings. It's tiding me over.
