- Jun 5, 2000
- 36,410
- 616
- 126
2004 camry, the amount of air coming out of my vents is really weak. I have replaced the blower motor (bought at NAPA) and replaced the cabin filter but still the air coming out of the vents is weak. i would equate it to the fan setting to set between low and medium.
the only way i can get the air flow i mention above is to put the a/c setting on recirculate. if the setting is on fresh outside air the air flow is equivinat to being set on low.
what else can i check to fix this. its annoying me.
the A/C cooling works just fine, i keep a thermostat in one of the vents and it sits at 40 degrees.
