Block dropped onto spring, how far is spring compressed?
MikeMike
45,885
66
block mass m dropped from height h onto spring with K how far does it compress?
what is the formula for this??
studying for final in 3 hours.
KillerCharlie
3,691
68
Conservation of energy... energy = constant = potential + spring energy = mgh + 0.5*K*x^2, where x is the distance it compresses.
Energy before dropping: mgh (all potential energy, no spring energy)
Energy after dropping: 0.5*kx^2
Energy before = energy after... mgh = 0.5kx^2
Therefore, x = sqrt( (mgh)/(0.5*K) )
There is one important assumption I'm making here though... that x is small compared to h. If this is not true, then that deflection x will cause additional loss in potential energy. If this is an introductory physics course, then I'm sure you can neglect this additional potential energy loss.
If not, x would be found as follows, assuming the top of the uncompressed spring is the datum (the reference line from which you measured h).
Energy before = mgh
Energy after = 0.5*kx^2 + -mgx
So mgh = 0.5*k*x^2 - mgx
Now you solve for x... which is a little messy
MikeMike
45,885
66
for some reason i know the answer (key) but its double the answer your formula is giving.
almost like they want the full amount the spring moves but do not specify this.
Zim Hosein
Super Moderator | Elite Member
65,294
403
I wish you sat next to me in Physics KillerCharlie! :eek:
KillerCharlie
3,691
68
What answer are they giving?
KillerCharlie
3,691
68
:confused:
That's odd... I'm sure I'm doing this correctly. I haven't taken physics in 3 years but I've tutored students some semesters. Unless I did something wrong (since my brain shut off because I just finished finals, woohoo!), then I'd say their answer is incorrect.
MikeMike
45,885
66
Originally posted by: KillerCharlie
:confused:
i think the part thats in parenthesis that says (The block moves back upwards) means assume upward movement as well.
