Blender cover for sound deadening?
TridenT
16,800
45
Anyone know of a good Vitamix blender cover that they've used? I'm considering just making one too. Shouldn't be too hard to buy some materials and glue them together to make a decent cover to keep the sound in. (Maybe I'll make some venting ports too) I don't usually make more than one smoothie at a time but it can take a couple minutes.
Would have to make a little gasket port at the top so the plunger could still be used but still block some sound.
Gibsons
12,530
35
A cardboard box. If you're worried about ventilation, get a bigger one.
Pros: it's free, it has other uses.
Cons: it looks like a cardboard box.
13,927
Wrap the whole thing in Owens Corning fibreglass insulation.
Just don't eat it, as tempting as it may be. It's not cotton candy.
effowe
6,012
18
Can't be louder than the Blendtec. That thing drowns out all conversation within 15 feet while it's going off.
Squisher
21,204
66
sdifox
100,891
18,090
Build your own hushbox? Personally I depend on the change in pitch to determine readiness.
sdifox
100,891
18,090
[QUOTE Anubis, post: 38554408, member: 68185"]im not sure why you need one[/QUOTE]
He couldn't hear the fruitloop crunch otherwise.
z1ggy
10,010
66
The sound comes from the loud ass motor that's spinning at 1000's of RPMs. Unless you are crushing rocks inside that thing, no kind of "cover" is going to keep the sound "in". You'd have to literally put the whole thing in a sound proof box to make it quiet.
No wonder you couldn't get a job.
Reactions: MongGrel
nakedfrog
63,186
19,520
I proposed a perfectly viable solution :colbert:
TridenT
16,800
45
So that's what Jamba Juice uses.
No, I think Jamba Juice uses these: https://www.vitamix.com/Commercial/Products/Beverage-Blenders/The-Quiet-One
You can dampen it or morph it in a way to get it to be quieter. I've seen demos of them being used.
