- Jul 17, 2008
- 1
- 0
- 0
My wireless connection drops randomly as far as I can tell. Whenever it disconnects I check ipconfig and the default gateway line is blank. Eventually the connection will come back online and the default gateway will be restored to normal if I wait long enough. Not sure how long it takes, seems random. The only way I've found to speed the reconnection is to go to services.msc and enable then disable Wireless Zero Config.
One thing that I should note is that I've had a very weird setup for awhile now concerning my wireless adapter. When I first set up my wireless network adapter (Linksys usb wireless adapter, 802.11b) it would disconnect for a few seconds every 60 seconds exactly. After some fishing around I found that if I used the linksys software that came with the wireless adapter I wouldn't have this 60 second disconnect interval so I could enjoy my games in peace. However, if my connection is dropped for any reason or when I first turn on my computer, I need to enable Wireless Zero Config to connect to my wireless connection first then disable it and switch over to the linksys software. The linksys software gives me a stable connection but can't get the initial connection, Window's Wireless Zero Config can make the initial connection but drops every 60 seconds. Weird, but I live with it. If anyone has a solution to that, I'm all ears too.
Whether WZC is on or off, I still get random disconnects nowadays and every time I disconnect the default gateway is blank. I'm not sure if that tells you anything, but it's the only thing that I've noticed that is different between when I have a connection and when I don't. The act of enabling or disabling WZC seems to bring the connection back almost immediately though. Edit: ipconfig /release and /renew seems to work as well. As far as I can tell, the other computers connected to my router don't experience the same problem.
Setup Info:
- Windows XP SP2
- Linksys wireless g "WRT54G" router
- Linksys "WUSB11" usb wireless adapter
If there is something else besides ipconfig /all that I should be checking that could give more pertinent information, please tell me and I'll post that information as soon as I can. Thank you in advance!
Setup Info:
- Windows XP SP2
