Black Ice Pro vs D-tek Pro Core rad?
PrYnCeQT
27
looking to get one of these guys for my wc setup. which one is better? i can't seem to find a review on the D-Tek one. is there anything else out there that's good? i can't use a huge one in my SLK3700BQE case, something a lil bigger than a 120mm fan that can fit into the case fan holes on the back of my case. thanks.
drewdogg808
1,513
the dtek rad is the better one...it's even better than the black ice extreme. it just depends if you have room for it. if you're limited to just the space of a 120mm fan, then the black ice series will fit better.
