This is kind of an odd problem. I put together my new PC last night without any problems (that part is not odd
). Upon bootup, I went into the BIOS settings and looked around. I then figured I would test my reset switch. When I pressed it, my system made an odd squeal sound for a split second and then reset. So I tried it again, but this time no sound. Later, after installing Windows XP, when I chose to shut down, the noise came back for a split second when power was lost. I tried another shutdown and it made the exact same sound again. After trying shutdowns and resets over and over again, I would have to say it's about a 50/50 proposition as to whether it will make that odd sound. This is without any speakers connected. It's a sound coming from the actual computer, and it doesn't matter if it's from within Windows or sitting in DOS or BIOS screen, etc.
I'm curious if anyone else has experienced an issue like this? Not that anyone is above making a mistake, but as a side note, I'm not a noob when it comes to system building (did it for a living for a local computer company for many years), so some of the easier explanations probably don't apply (example: didn't leave a scalpel in the fan blade during surgery
). Any feedback is appreciated!
CPU = E6850
Mobo = GA-P35-DS3R
GPU = EVGA 8800 GTX
RAM = 2x1GB Corsair
PSU = 650W Seasonic
Case = P180B
Audio = X-FI Gamer
HD = 80GB WD Sata
CPU = E6850
Mobo = GA-P35-DS3R
GPU = EVGA 8800 GTX
RAM = 2x1GB Corsair
PSU = 650W Seasonic
Case = P180B
Audio = X-FI Gamer
HD = 80GB WD Sata
