Alright so here's the deal:
I was toying around earlier with the OC on my GTX 580s (WC) using MSI Afterburner. I decided to try ramping up from 1000mhz core clock (1.15v) to 1050mhz and increased the memory clock from 2004mhz to 2200 mhz (2004mhz was stock). The temperatures went up from about 37C load (GPUGrid) to 57C and then the screen blanked out and came back but was artifacting so I immediately removed the OC and restarted the PC. Everything booted up fine with no issues.
But then I noticed when I started GPUgrid again I was only getting one task (SLI disabled when I'm on BOINC). So I looked at Afterburner and one of the cards was at 0% consistently. I got worried and ran Kombustor to see if the same thing would happen when I put it into SLI and ran a test. Sure enough it did stay at 0% (would downclock from 398mhz to 0) but it would always start off working for a second. I'm fearing the worse that I may have ruined one of my cards. To find out, I tried turning off SLI again and switching my second display into the second card to see if it would send a signal and sure enough it did. Any other ideas on how to figure out? I'm gonna be super pissed if it turns out I messed up a card, feel like an utter moron.
