A few months ago I wired a network into a home consisting of 3 drops...structured cable, used a patch panel, etc. Did everything the right way. They only had one computer and it worked fine for the drop it was connected to. I used my CAT5 tester to test the other two drops and they tested fine. They have since moved the computer into another room and get the "MEDIA DISCONNECTED" error. I brought my laptop andconnected it to the same drop with the same cable and it works perfectly. So I thought hmm, bad NIC. Bought a new NIC and I still get the media disconnected error. So I thought hmm..bad motherboard? So I tried using a different computer(350mhz..old computer)...STILL get the media disconnected error..yet the laptop still works perfectly.
Bizarre right? I've tried messing with every setting..I have no idea what the problem is. It just doesn't make sense. The only difference in ipconfig /all is that on the laptop it says "Node Type: Mixed", while on the computer it says "Node Type: Broadcast". I have no idea what that means or how to change it..but it was the only difference.
Also, the NIC on the laptop is gigabit while the other 3 nics I tried with the desktops were fast ethernet. Any ideas?
The patch cable says "verified to EIA/TIA568B .2 CAT5E" I punched down the keystones and patch panelaccording to 568B standards, not A. Could that be theproblem? I have a feeling it has to do with the gigabit nic perhaps?
I really don't know..extremely confusing!
help please..thank you.
