- Mar 18, 2008
- 7
- 0
- 0
I'm using Windows XP
So, when I reinstalled windows into my 40 gig HD (C
, some kind of bizarre glitch occured, causing the maxiumum hard drive space to be set at 2 gigs.
This would not fuss me particularly, except that the actual windows files take up about two gigs. Windows isn't smart enough to redirect all temp space to my bigger hard drive (D
, even though I have gone into all the base settings and told it to do so. Some applications, especially microsoft applications, insist on using drive C: for temp space anyway.
So basically, this means that I cannot install the latest security update, and many programs have serious problems, not to mention the annoying, "drive C is low on disk space message", which is permanently affixed to the lower right hand corner of my screen.
I don't really want to reinstall windows, and that probably wouldn't fix my problem anyway.
So I have come up with a basic plan, hopefully you guys can help me put it into action.
What I want to do, is extend the drive space of C: using space on D:. I have magicpartitition. I was thinking, I could set a partition on drive D: which is about 2000 megs. After that, all I would have to do, would be trick my computer into thinking that that partition was part of drive C:. I don't know if this is possible, but I am simply looking for some way to use a small part of the huge amount of extra space I have on D: as an extension of drive C:.
If I could have even 200 megs more space on drive C, that would alleviate most of my problems.
Does anyone know of a program that will help me make this happen for myself. I would love to get this solved.
If you have a solution feel free to AIM me at YoshonX, I will be most grateful.
Thanks a lot for any help guys.
