Bizare drive problem
Schott
Okay, thought that my 3 mth old segate drive might be dying. It was making a strange clicking sound when accessing certain folders, and taking up to 30-60 seconds to open them. Checked online tools at seagate and SMART says it is ok. Did the short and long diagnostics, and it says it was fine. Ran a full scandisk and it was fine. Checked virus, spyware, etc. Everything fine.
Logged on under the only other user (which is not a system admin account), and guess what? It works fine. Made a new user account, and it is fine.
This is so strange. Only happens under the admin account, and only on certain directories.
Also, sometimes when it is waiting for the window to open on the folder you select, you will get a prompt saying that drive C: is not formated, and if you want to do so. My C: drive is my systems drive with XP on it. The drive which is giving me heck is G:.
Any suggestions? I really have no idea on this one...Thanks!
Hi There!
I've had this issue before, and it usual relates to the account profile becomming corrupted. make a new admin account and transfer data over.
MikeHP
How about making a new admin account and see if the problem goes away. If it does, then just move the rest of your old profile to the new account and delete the old one. If the problem follows with the new admin account, check the task manager and make a comparison of the processes running under an Admin and Non admin account.
