Bitfenix Prodigy USB 3.0 Mini-ITX Tower Case $60 + FS
Status
Not open for further replies.
secretanchitman
9,352
23
Thanks OP! Honestly haven't bought a case in years but I am seriously loving the look of this case. Hope they wont come out with an updated one soon :p
Feb 4, 2009
35,862
17,403
Does this take standard atx (antec earthwise 620) power supplies? need a replacement machine soon and the girl would probably like this.
CuriousMike
3,044
544
I was just researching whether my Antec would fit; my PS is 160mm deep which is the largest it will accommodate; reading up on this case, it seems like a crapshoot if 160 fits with ease or with force.
I didn't see 'earthwise' on antec's site, but earthwatts. The only 620 I found listed was the Eco 620 at 180mm deep, so that would not fit.
QueBert
22,951
1,140
I have this case, my PS is I think a hair under 160 (Corsair hx520) and it fit, but it's not exactly a good fit. It's kind of crammed in there, but it wasn't hard to get it in. This is a weird case, it's stupid large for ITX, but it's not big enough to comfortably house things like higher end PSU's without a lot of research.
QueBert
22,951
1,140
Buyer beware, it is not uncommon for these Prodigys and other Bitfenix cases to ship with USB 3.0 front panel cables that are defective and do not work with USB 2.0 devices. I have one and went through a PITA to get it working.
I have a Corsair HX520 modular PSU I have been using for at least 4-5 years and it fits. It's tight but it fits.
http://www.bitfenix.com/global/en/forums/search?term=usb+3.0+front+panel+defective
It's not exactly a defect, I had the same issue, I forget how I got it working. But there is a process that makes it work normally.
ClockerXP
1,940
Your statement only partially true. Bitfenix admitted the defect in their forums and to me via email.
There were some people having issues with drivers not being loaded correctly or BIOS settings not being right. I tried everything those people did, still with no function of USB2.0 devices. There are many others in the Bitfenix forum with similar experiences. To prove my theory I purchased an aftermarket motherboard header cable on eBay & that fixed the USB problem with no other changes to the system. Bitfenix finally sent me a replacement cable that would work with their PCB after 3 months begging them for one and that one was OK too.
Plugging back in the original cable causes the port to not work correctly with USB2 devices on demand. I suspect some of the pins/leads are either mis-wired or just not connected in the defective cables that are getting to customers..
Status
