BitFenix 3-pin to 3 x 3-pin Fan Adapter Cable - 60cm - Blue Sleeve
bleucharm28
495
So im planning to get these 3-pin to 3 x 3-pin Fan Adapter for 3 Noctua NF12's (120mm) and 3 Scyth Gental Typhoon (120mm)
My question is will one of six channel work with 3 120mm fans? I pretty sure it doesn't, but what kind of fan controller do I get? at 30w per channel or 50w per channel.
Any feed back be great thx
Model Name: Kaze Q8 8-Channel Fan Controller
Voltage Range: 5 V (±10%) - 12 V (±10%)
Fan Channels: 8 channels
Output Ampere: max. 1 Ampere
Fan Speed Range: 0 - 9,900 rpm
Weight: 110 g / 3.88 oz
Accessory: Unit (x1), Fan Cable (x8), Power Cable (x1), Screws (x4)
