tigersty1e
- Dec 13, 2004
- 1,963
- 0
- 76
Just so we are clear here.
6970 = 176GB/s
6950 = 160GB/s
6870 = 134GB/s
5870 = 153GB/s
5850 = 128GB/s
4890 = 124GB/s
4870 = 115GB/s
5770 = 76GB/s
Now look at the 5770 vs the 4870/90. The is a huge gap in bandwidth between the cards, but performance is very similar. Same SPs, very similar clocks. So how do you explain that.
Looking at the 6950, 5870 and 6870. The 6870 is closer to the 5870 in performance than the 5870 is to the 6950, but bandwidth favors the 5870 heavily against the 6870. How do you explain that too?
AMD have been using GDDR5 since 2008 with the 4870, I'm pretty sure they can get their memory controller working with higher speeds when the 7000 series is released. Who knows what kind of speeds the controller in Cayman can handle as it can easily max out the 6ghz of the GDDR5 that the 6970/50 come with.
comparing the 4890 to 5770 is more comparable considering they both have the same core speed. performance is not very similar. the 4890 significantly beats the 5770. the jump from 5770 to 4890 is similar to the jump from 4890 to 5850.
you have to realize that everybody loves to rave about their equipment. the 5770 is probably the most bought card from that gen and "everybody" kept saying their 5770 was as fast as a 4890.
again, where are you getting your numbers? the 5870 is closer to the 6950 than it is to the 6870.
http://www.anandtech.com/bench/Product/294?vs=293
http://www.anandtech.com/bench/Product/290?vs=294
amd using ddr5 since the 4870 is exactly my point. they vastly improved their controller on the 2nd go-around. 900 to 1200 (33%)....1200 to 1375 (15%)....1375 to ...definitely not 1500.
the perfect storm with die shrink, mem speed increase is what gave us nive 4890 to 5870 boost.
