StrangerGuy
- May 9, 2004
- 8,443
- 124
- 106
Intel launches are so good that they can say X% IPC increase, Y% less power draw etc and no one will bat an eyelid.
Off topic is good. If you do enough of it, you can obtain a post count like mine.![]()
Ivy is not delayed,when was intel supposed to put a tick and a tock out in the same year?
sandy e is delayed a little but it never got an official release date anyways.
Just like I told the AMD camp,intel will leak out all its up coming cpus right before AMD launched BD to kill there sales.
The one you're waiting for is coming in 2013! Haswell. If you're waiting for IB with SB in your rig, well you're not going to see much improvement unless you plan to use igp, or mobile versions.
Sandy Bridge E was supposed to be out earlier but was delayed a little bit. Ivy Bridge most certainly got delayed a bit from when it was intended to come out which was very end 2011 or very beginning 2012. it will now be out in the Spring so YES that is a small delay.Toyota said ivy bridge is delayed,its NOT...intel was never going to put a tic and a toc out in the same year.Ivy bridge from day one was supposed to come out in the year 2012 or get specs at end of 2011.
intel does not put out a shrink of the same chip in the same year.
That is all Im saying,its not delayed its actually right on sch.
lol +1 this...
this is what ive been telling everyone..
you are right, Ivy Bridge is coming out right on schedule and has not been delayed by even a day...can you show me where intel was supposed to release a new arch and a shrink of it in the same year?
no where was ivy bridge supposed to come out the same year as sandy.Intel does not do a tic and a toc in the same year.
ivy is right on sch and will come out shortly after sandy E.It was never supposed to come out the same year as sandy came out in.that dosnt make any marketing sence at all and is a waste of making a 32nm sandy
Man your a glutten for punishment. You did the same thing with SB . and look how that turned out . IB . is even a bigger impact than SB .
Increase all over clocking values min, of 500mhz.
The Igp improvements have to be included now that IVB is DX11 CL1.1.
No no no, the one you REALLY want is the one AFTER that.
*My statement may change after a couple years.
IB . is even a bigger impact than SB . Increase all over clocking values min, of 500mhz. . I won't debate clock for clock gain again .
did you even read any of these links? IB looks to be way more than just a simple shrink. it looks to have many small improvements and also a small IPC increase. sure clock for clock it will not much faster at all but it will be way more efficient and can allow for higher overclocking.Ivy Bridge is just a die shrink. Sandy Bridge was a completely new architecture. Of course IB won't have as much impact.
Overclockers look forward to every die shrink with excitement. At least, I sure do.
Ivy Bridge to be the first CPUs to hit 5GHz without putting the CPU at risk?
Sounds like an exciting CPU.
My point was purely from the performance perspective. In that respect, i5-2500K was a much bigger jump over i5-750 than the i5 Ivy Bridge will be compared to 2500K. And this is because it's not a new CPU architecture, but a die shrink.
