Biostar TP67B+ motherboard w/2500k help me oc it!
SpeedZealot369
2,778
Hey so I just got this new build up and running. Had a little issue with the power supply but that is fixed now.
So here are my specs:
I got a 2500k used
biostar tp67b+ new
ULTRA X-CONNECT 700W used
8gb ram from newegg new
gtx 570 cu2 used
120gb cosrair 3 ssd used
1tb HD used
So I tried overclocking it with this guide:
http://www.youtube.com/watch?v=7lCxjJnN__A
And I couldn't get it to run, I even lowered the multi to 41 and I got a blue error screen after that.
So Anyone here use this board and can give me some advice as to ocing?
On a side note, I have a sound blaster xfi fatality pro, and I went to the website to download drivers, and they said they don't support windows 7 64 bit? Is this true?
anyway thanks!!!
CU
2,415
51
You sig show you have it running at 4.1ghz. Is that as high as it will go? What are your temps?
CU
2,415
51
Assuming you did fix your problem. What did you change?
