So I'm in the midst of putting together a HTPC/kid-PC. My parts list includes an i3-530, a Biostar TH55B HD, and some GSkill DDR3.
First power on was nice, but one thing I noticed that right out of the box the CPU was clocking in at 3.01GHz. Now color me confused, because the 530 is a 2.93GHz part. Mild overclock, fine. I purchased this chip from a good friend and know it can handle it (he had it upwards of 4GHz).
Installing windows itself was slightly odd, it did a few things I've never seen it do before (Win7, a few intermission screens and reboots which I have never seen on several builds), but in the end it worked fine. No desk in the living room yet, so I put the computer aside for the last week.
Tonight, I decide to hook up the spare monitor and finish updating everything, windows boots, logs in, then the video driver proceeds to crash, followed by Explorer, followed by a BSOD claiming MEMORY_EXCEPTION. Well that's odd.
The mobo BIOS is kind enough to have Memtest 2.11+ built in, so I reboot and let her rip. Bam, 437 errors within 10 seconds. Up to 900+ after 2 minutes. Bum ram?
Check the ram SPD settings (Biostar is nice and even lets you pull the full SPD table in the BIOS). The ram should be fine, it's 1333Mhz stuff rated 1.5v and timings look fine. As I'm poking around the BIOS, I notice that VDIMM is running a little high - 1.6v. This is also something I find odd, since the ram is indeed spec'd at 1.5v. Finding the OC settings is counter-intuitive in the bios, but I manage to find it. VDIMM voltage is set to Auto, so I look - Auto is apparently where 1.5v should be, but there's no "manual" 1.5v setting, so I took the next best thing which is 1.55v, and also set the ram frequency down to 1066Mhz.
Reboot, and running memtest now with 0 errors so far during the time it's taken to type this post. Currently at 57%. Also noticed the clock speed on the CPU is proper now too - 2.93Ghz.
Feels like a "load optimal bios settings" is a recipe for epic fail on this board apparently.
Cliffs for the literary challenged:
1. New build
2. Mobo "overclocked" CPU out of the box
3. Epic failure crash with BSOD, apparent memory issue
4. Mobo "overvolting" RAM, apparently causing memory errors
5. Manual settings save the day
1. New build
