Biostar TForce4SLI problems
Glendor
3,911
Specs:
Biostar TForce4 SLI w/ latest bios
Opteron 165 (also tried 3500+)
4x Corsair 512mb CMX512-3200XLPro w/ actvity LEDs
600w SLI approved PSU
Two GeForce 7950GX2 video cards in SLI (Quad SLI)
SATA Harddrive & DVDRW
Note one: All the hardware above was working perfectly on an Abit Fatal1ty AN8-SLI before being moved to the Biostar mobo, and it works perfectly when moved back to the Abit board.
Note two: With only one 7950GX2 card installed, the video works correctly, but the memory problem (if it is a problem) still remains.
Problem one: When the 2nd 7950GX2 is installed, and the SLI Key is changed to SLI Mode, and the SLI Bridge is connected to both cards, the computer no longer displays video output during the POST stage of the bootup process. Video comes back when Windows loads, but nothing from the time it's powered on, till you get to the Windows logon screen. Makes it impossible to get into the CMOS while two video cards are installed.
Problem two (possibly related to one above): After each reboot, the Windows resolution resets to 800x600, and must be manually reset to 1024x768. With only one card, it doesn't have this problem.
Problem three: Only memory modules 1 & 3 display activity even though Windows shows that there is 2048mb of memory in dual channel mode. The same combination on the Abit board showed equal amounts of activity on all four modules.
Help...
