Bill Kunert
I have a Phenom 8750 on a Biostar MCP6P M2+ with 4 gig of PNY 800MHz ram. If I raise the clock speed even 5MHz from 200 to 205 it will often give a message on boot that it is defaulting to standard frequencies. I've had it boot sucessfully at 2.8GHz and when it does boot it runs fine and will pass Orthos for over an hour. At that frequency I set the memory back to 667MHz. Is there any way to disable the function on this motherboard that causes overclock to fail? I've searched the forum and others with this motherboard are getting decent overclocks with, apparently, no problem.
Thanks
Thanks
