i have a xp1500+ factory unlocked cpu, its running at 1.1 ghz at 137 FSB (max in BIOS), i cant find the clock multiplier in the BIOS and i flashed the BIOS which didnt help.. anyway, i downloaded SpeedFan 4.05 which can change my FSB higher than 137, only problem is i dont know what setting i should enter, my choices are
Clock Generator :
ICS 9148B-04
ICS 9248 (ABC)F-199
ICS 9248-90
ICS 9250-18
ICS 94225
PhaseLink 205-03
any help will be appreciated, im on aim/yahoo/msn messenger also
My Motherboard/BIOS/etc
http://www.biostar-sw.com/products/mainboard/socket_a/m7vkd/
Clock Generator :
ICS 9148B-04
ICS 9248 (ABC)F-199
ICS 9248-90
ICS 9250-18
ICS 94225
PhaseLink 205-03
