Biostar M7VIG for low end upgrade?
tommyjt24
67
well i dont want to spend the money to get the ddr but what do you all think of this board? has usb2.0 atleast.
Killrose
6,230
8
Is that the one with the SDR/DDR ram slots that allow you to upgrade? As long as it has an AGP slot, the price is cheap. I have heard from many people the on-board video is good for web surfing and low resolution gamming, but that's it. Probably be fine for a K-6/early Pentium up-grade system, and if you pick up some DDR later it would be decent.
tcsenter
18,895
548
Go for the "Pro" version of the M7VIG, it has the VIA VT8235 SB, integrated USB2.0, and six-channel audio for the same price or very close as the M7VIG. The non-Pro M7VIG uses the VT8233A which is USB1.1. I have the non-pro version and it works fine. Limited overclocking potential; no CPU voltage adjustment, but it has some FSB adjust options in BIOS and DDR voltage adjust (by jumper).
Only problem I have to date is that my manual and automatic standby function disappeared from Power Management and Shut Down options when I switched to the M7VIG. I have ACPI disabled in BIOS because 'classic' APM suits my needs just fine and using ACPI can often cause "glitches" of various sorts. I have tried re-installing the VIA drivers, removing PCI BUS from Device Manager, and allowing Windows to redetect all my devices again, without success. I have not tried installing Windows again, because that shouldn't be necessary, but I may try it.
I suspect its a BIOS oversight or flaw. I am going to fill out a problem report and send it to BIOSTAR to see if they will address the problem in the next BIOS release.
