- Jun 22, 2004
- 126
- 0
- 0
I recently purchased a Biostar M7NCG to build my first SFF system. Here are specs:
Mobile 35w 2400+ AXP
Biostar M7NCG 400
2x256 Kingston Hyper-X PC3200
Speeze Ball Bearing Copper HSF
PNY Geforce 6800NU
SoundBlaster Audigy 2 ZS
120gb 7200RPM Western Digital Special Edition
Antec Aria
When I put it all together, it won't POST at all. Everything turns on fine (hard drive, all the fans), but the monitor just wont turn on. When I took the 6800 out, it turns on, but just hangs when it says AMD Athlon Chip 600mhz. No memory count, no IDE detect, just hangs there. I can't enter CMOS, can't do anything. I've tried switching the memory in every possible slot combination, as well as taking that hard drive and optical drive out. The only thing I haven't tried is reseating the CPU, since it was a complete pain to get the HSF installed as it is.
My guess is that its a memory problem, since I don't get a memory count at all. I haven't tested new RAM yet, since I just put it together today. I'm not sure what version motherboard I have, since I don't know how to check. I can probably test some new RAM tomorrow (Kingston Value RAM).
I originally bought a Chaintech 7NIL1 instead of the Biostar, but RMA'd it when I realized how poor the BIOS was for overclocking. With that motherboard installed, I got it to POST fine, but it either froze loading Windows or when Windows was loaded. With that said, I know the RAM works, unless that was why Windows was freezing (never had this problem with my older system). My guess for why it was freezing though was because I had a mobile AXP and no multiplier or voltage to increase the speed.
Obviously if my motherboard is a dud I'm going to RMA it. If anyone could help me out I'd really appreciate it.
Thanks in advance.
Biostar M7NCG 400
PNY Geforce 6800NU
Antec Aria
Thanks in advance.
