I switched my ram sticks as i realized i was only using one channel. Booting up i got an error saying BIOS ROM checksum error. I can not access the BIOS settings as it says Award BootBlock BIOS v1.0. It then tries to load my CDROM and my Floppy drive. It will load awflash.exe from the CD ROM to try and update the BIOS. It then says ""see if lockout jumpers are set to correct" and it will not update from there. I have removed the battery and used the jumper to reset the BIOS and nothing. I burnt the AWflash.exe and the asus1008 update file to the CD. It says to use a floppy so im not sure if thats my problem. My specs:
Asus A8N-E
athlon 34 3200+
OCZ 1024 dual channel 2-6-6-8
PS i have the ram in 1 and 3 now. I had it in 3 and 4 originally. Switching it caused the problem, switching it back fixed it. I then removed the battery for 20 seconds and reset and now the 3 and 4 setting wont work. Thanks!
Asus A8N-E
athlon 34 3200+
