Bios Settings review for the experts
bramdo
154
Hi Guys,
I hope these bios settings are any good according to the specialist (you) opinion. Problem is that I also have the CPU Core and real temp issue where under prime the CPU gets 70 dregrees celsius under load when oc to 3.2 ghz and 55 idle. In realtemp it's 60 load / and 50 idle despite the noctua cpu cooler . I would like to change these settings to get save 3.00 ghz but i dis my homework for the 3.2 ghz and forgot how to change the settings to 3.00 ghz (voltage etc)
Please take a look, Thanks Bram
Ai Overclock Tuner = Manual
OC From CPU Level Up = AUTO
CPU Ratio Control = Manual
- Ratio CMOS Setting = 8
FSB Frequency = 400
FSB Strap to North Bridge = 333
PCI-E Frequency= 100
DRAM Frequency= DDR2 800
DRAM Command Rate = 2T
DRAM CLK Skew on Channel A = Auto
DRAM CLK Skew on Channel B = Auto
DRAM Timing Control= Manual
CAS# Latency = 5
RAS# to CAS# Delay = 5
RAS# Precharge = 5
RAS# ActivateTime = 15
RAS# to RAS# Delay = Auto
Row Refresh Cycle Time = 50
Write Recovery Time = Auto
Read to Precharge Time = Auto
Read to Write Delay (S/D) = Auto
Write to Read Delay (S) = Auto
Write to Read Delay (D) = Auto
Read to Read Delay (S) = Auto
Read to Read Delay (D) = Auto
Write to Write Delay (S) = Auto
Write to Write Delay (D) = Auto
Write to PRE Delay = Auto
Read to PRE Delay = Auto
PRE to PRE Delay = Auto
ALL PRE to ACT Delay = Auto
ALL PRE to REF Delay = Auto
DRAM Static Read Control= Enabled
Ai Clock Twister = Auto
Transaction Booster = Auto
Pull-In of CHA PH1 Disabled
Pull-In of CHA PH2 Disabled
Pull-In of CHB PH1 Disabled
Pull-In of CHB PH2 Disabled
CPU Voltage = 1.45v
CPU PLL Voltage = 1.55v
North Bridge Voltage = 1.4v
DRAM Voltage = 2.1v
FSB Termination Voltage = 1.3v
South Bridge Voltage = Auto
Loadline Calibration = Enabled
CPU GTL Reference = Auto
North Bridge GTL Reference = Auto
DDR2 Channel A REF Voltage = DDR2-REFF
DDR2 Channel B REF Voltage = DDR2-REFF
DDR2 Controller REF Voltage = DDR2-REFF
SB 1.5V Voltage = 1.5
OCGuy
27,224
37
FSB= 375
Although I do recommend fully reading Graysky's guide so you understand what you are doing, not just how you are doing it.
Give a man a fish....
Teach a man to fish....
bramdo
154
Hello,
you're complety right about the suggestion (and the quote :) ).
However I misformulated my question a bit.
There are some things that I didn't find in the guides (like loadline calibration) and i wanted to check since learning by doing is sometimes dangerous :)...
Thanks
bRAM
aigomorla
21,073
3,576
Originally posted by: bramdo
Hi Guys,
This section is your FSB and Memory settings
FSB Frequency = 400 i can see your clocked at 3.2ghz
FSB Strap to North Bridge = 333 why not 400 strap?
CAS# Latency = 5
RAS# Precharge = 5
This is the chip killer potion. Meaning where you mess up you can kill your chip
CPU Voltage = 1.45v This is what we call bios voltage, not vCore.
CPU PLL Voltage = 1.55v i tend to never exceed pll voltage greater then core voltage
North Bridge Voltage = 1.4v long term loading will require you to prep board and maybe active cooling if you dont have one
DRAM Voltage = 2.1v this is kinda high for me as well try 1.95V
Loadline Calibration = Enabled trys to reduce Vdroop on load leave this on enabled
CPU GTL Reference = Auto dont touch this unless you know what your doing
Please read my bolded comments. :T
GuitarDaddy
11,465
I agree with AIGO, your voltages are too high for 3.2ghz, my x3350 runs 3.2v with actual load vcore of 1.25 (per CPUz under load) all other voltages at stock.
I would return everything to stock except vcore, run prime to make sure its stable, then begin reducing vcore and testing with prime until you find the lowest vcore that will pass prime
aigomorla
21,073
3,576
you know what i totally missed his question.
I thought he was asking how his settings were, not help me lower them.
Okey, OP first off i dont think your gonna see a super big improvement in temps from 3.0 vs 3.2.
So i would keep the 400 x 8 overclock you have, instead of going down to 3.0ghz.
Also try lowering the PLL.
Also lower the CPU Voltage.
If its a G0 it should hold your overclock @ cpu voltage 1.35.
Set PLL to 1.30-1.4 I dont think you'll need 1.4 You have it super too high.
After you do these changes, stress test it. Then if it passes, lower the cpu voltage more. Some G0's can hold that overclock @ stock voltage.
That should lower your cpu temp. Also i trust CoreTemp > RealTemp on a full blown kentsfield.
Q6600 = kentsfield.
GuitarDaddy
11,465
For the Q9450 yorkie I think realtemp is more accurate than coretemp. And I beleive the yorkie will be a C1 stepping.
aigomorla
21,073
3,576
lmao.
i found a bug on it, with my Q9650 ES.
:p
bramdo
154
Dear all,
thanks for taking the time to answer me. I hope when I study hard enough that one day I can help one of you but till than i can only express my gratitude.
What would be an good-excellent temperature for an oc 9450 to 3.2 ghz no load.
Bram
aigomorla
21,073
3,576
YMMV depending on voltage settings
meaning, your millage may vary.
Shimmishim
7,504
yes i agree it will depend on your voltage... but i was recently trying out a e8400 and i noticed temps didn't change much with voltage even with load.
with that said. i agree that you should drop your voltage from 1.45. it's way high even for 3.2ghz.
also never put the vtt or vfsb voltage above 1.45 for extended use. from what i've read, it can kill your cpu.
