Bios Question....Please Help
jwells777
346
Ok....so I just did my first bios flash which I was quite apprehensive about in the first place....Just when I thought I was in the clear....The newly flashed bios has created the need for a password at the bios screen!!!! I have no idea what this password would be since I have never had a system password. I downloaded this bios from the EPOX website and it is the official 711 release...If anyone can tell me how to get past this password I would greatly appreciate it...Thank You
Jennifer66
217
Clear the cmos with the power supply off or unpluged.
Look in the manual for the jumper its near the battery.
jwells777
346
Thanks for the tip...It worked and I am now at 167 Mhz FSB....Does anyone know how to check to make sure the 1/5 divider is working...also, I think the AGP bus is way out of spec, will this cause any problems? As always, any input is appreciated. Thanks
Jennifer66
217
SiSoft Sandra will show the pci bus speed in the motherboard section.
Your agp bus should be at 1/2 of the fsb or 83.5 and thats not too bad. Many people run GeForce 2 cards at 100mhz agp bus on bx boards.
No idea about your card but it should be good to at least 89mhz as only a few cards I know of cannot and they are older.
Nice overclock btw :)
What memory timings are you using?
jwells777
346
Thanks for the info...I heard that Sisoft won't report anything higher than a 1/4 setting though...My mem timing is on "Normal" which is a CAS 2.5 setting. I have a Radeon LE for the record. So far it seems quite up to the task.
BraveSirRobbin
850
I would use a benchmark test to make sure your system is stable if you continue to run at 167 FSB. All may seem well until the system is stressed.
