- Feb 23, 2003
- 747
- 0
- 0
Question about water cooling additives. Is there a suggested additive to use to prevent algae build up or micro organisms?
-sponge
-sponge
Originally posted by: EvilSponge
Sorry Aig I use both leds and cold cathodes so 2 drop in res got it thanks. I do live in Florida where the change of algae growth is greater.
-sponge
Thanks Aig last question leak test outside case if no leaks then install all components in case correct?
-sponge
Safety first! yeah I'm going to take it slow as it is my first water build. Thanks for all the help Aig I'll post pictures of my test loop once I get the pump. Will a 120mm single fan radiator be enough to cool a 8800GTX Ultra?
-sponge
